Prop centre bearing. New item, dry?
hillbilly30
Fri Oct 04, 2013 6:45 pm
Hello all, have fitted another centre bearing, it's was fine for 10 miles but started making scratching dry noises, sprayed it with wd40 type lube and was fine for a few miles but noise has come back. Am thinking a thicker spray grease like white grease would be better?? Anyone had this issue before! Don't fancy swapping it out again!
mrLEE30
Sat Oct 05, 2013 12:24 pm
did you pre load the bearing?
if not then try this first, with the bearing housing in a finger tight position, slide the bearing housing about 5mm toward the gearbox and tighten in this position.
Also WD40 is not really a lubruicant as such, in fact it acts as a degeasing agent, so spraying WD40 on a bearing is only a short term fix as it stop noise for a while but also washes grease away ultimately shortening the life of the bearing.
hillbilly30
Sat Oct 05, 2013 1:30 pm
Thanks mrlee but I have an update, I've today noticed that the factory grease is oozing from the casing, also the rear of the bearing case is loose in the housing! So I/and Richard off of BBB think its toast! So that's a grand total of 80 miles from a brand new part! Thanks GSF! Genuine item next please.
Rob_farmer
Sun Oct 06, 2013 6:09 pm
There are decent aftermarket parts out there, just don`t buy cheapest, they could be made in China.
I`m driving E30, 1989, 325i, 4 door. Restoring 1990, 4 door.
Sun Oct 06, 2013 10:19 pm
Easiest way to ruin a brand new bearing is to damage one of the grease seals when you fit it, pushing it inwards so that it fouls the ball cage.
TommyM
Sat Oct 12, 2013 4:38 pm
Hi just reading up as my centre bearing has given up. From what ive read looks like what was said above about sliding bearing forward to gearbox or on a m3 its backwards might not be true as im just looking at google ha. Where did you buy the bearing from? Anyone recommend a good place for aftermarket parts?
zd3bx
Sat Oct 12, 2013 5:59 pm
It's better just to buy it already inserted into the carrier, so there won't be any hassle fitting it.
I've got Febi one (Febi part no 02823), plenty on ebay for £25-30, but that's for a facelift...Older E30's might have a different part number.
TommyM
Sat Oct 12, 2013 6:26 pm
Mine has actually broke away from the carrier so will be needing whole thing. Will check ebay and see what stores are so not getting a chinese copy
