2.0 same as 2.5 flywheel
CarlNewman
Post Fri Oct 11, 2013 2:18 pm
Hi, Im in the process of swapping out my 2.0 with a 2.5. the 2.5 engine i have is a early spec so the crank sensors are on the bellhousing which pick up readings from the flywheel. Can i use my 2.0 flywheel or will i need to get hold of a old spec 2.5 flywheel as it may have a magnet of somekind?
thanks
jimbom30cab
Tech 1 freak
Post Fri Oct 11, 2013 2:26 pm
I think they work on the hall effect
have you cross referenced the part number on realoem ?
gromgsxr
Post Fri Oct 11, 2013 3:59 pm
If you are using the early management with the sensors in the gear box you will need the early flywheel to go with, and I think you will need the matching starter motor.
age
Formerly twist316
Post Fri Oct 11, 2013 6:22 pm
Thats correct correct the later starters don't fit the early flywheels and vise versa
M40 rightness if you can get to 6000rpm noone can hear your tappets
