Rocker arm lock
Mindelis
Post Wed Oct 09, 2013 9:48 pm
Hi, at the moment i am rebuilding m20b25 engine. And now i put head all back together and can you tell me how can i lock rocker arm shaft in position. I have this locking thingy to lock it in the side where is camshaft pulley, but i dont know what part i need to lock other end of rocker arm shaft?
maggspower
Turbo Farmer Tractor Driver
Post Wed Oct 09, 2013 11:25 pm
It only gets locked on the cam end with the little tab you have.
Post Wed Oct 09, 2013 11:39 pm
it only needs No6 as shown here,
it should fit snug, the rocker cover holds it firm in place,
ross2009
Post Thu Oct 10, 2013 7:01 pm
theres 2 slots in the shafts you have to line them both up so there vertical only then will the locking key go on
Turbo M20
v8 project 6.0 twin turbo
