e30 m30 1/4 run
drai
what 1/4 times could you get from a e30 with a m30,m50,m52 or m20 2.7. thinking of doing a engine swop or rebuid which would be best for 1/4 run? any info would be great.
hillbilly30
Have a scan through you tube, lot of vids up on there! Having never done 1/4 mile in an e30 I've no idea
think. M52's are doing mid 14's
leeparkes
M30 = mid 14's
M52 = low 14's
M20 2.7 high 14's
M52 is best on a quarter mile because you can keep it in the powerband (4.5k-6.5k) all the way through.
On the road is a different story.
Imo i wouldnt bother with an M20 if power is your thing unless you are bolting a turbo to it.
M52 = low 14's
M20 2.7 high 14's
leeparkes
Depends on the E30 too, ie if you are using a touring or cab the weight will be an issue, for some reason the lightest E30 is a 2 door chromie
maggspower
- Turbo Farmer Tractor Driver
That will be the rustleeparkes wrote: for some reason the lightest E30 is a 2 door chromie
Contact: theengineshedonline@gmail.com
sunnysr
Any idea`s on the actual weights of e30s i have looked a few places and seen a few different weights depending on what site.Has anyone had theirs on a weigh bridge ,im most interested in tech1 sport weight ,and also weight of a stripped out one say for track use but not extreme ?leeparkes wrote:Depends on the E30 too, ie if you are using a touring or cab the weight will be an issue, for some reason the lightest E30 is a 2 door chromie
craigieeb
**Cough**leeparkes wrote:Depends on the E30 too, ie if you are using a touring or cab the weight will be an issue, for some reason the lightest E30 is a 2 door chromie
13.9 with the M52 in the touring
M50 Turbo!!!
I shall say no more
zaust
- Zone day release
