I was wondering if anyone had any photos or diagrams of how the interior loom is run. I took some photos but cannot find them now.
Any help would be much appreciated.
Loom routing photos
bigbird76
have a look at X works writeup on the forums, He has pictures regarding where things go on the M3 but I am sure it would be the same on other models.
Leigh
Leigh
Jozi
I have pics for a touring i can post up if you want?
Andeep
Yeah that would be great if you can please
Jozi
Turns ou I only have images of how the wires run in the boot and behind the dash. Either of these any good to you at all?
Andeep
Yep anything will help mate
Jozi
They might not all be relevant! I took them as I was pulling the dash out. The boot one might not be the same at all because it's from a touring
Dash:
Boot:
Dash:
Boot:
Andeep
Perfect! Thank you for those!
Jozi
No bother at all. If you need anything else just post, I might be able to help as I still have the shell here.
Andeep
Could you tell me where the following black plug is meant to go? Its located in the drivers footwell and next to the central locking module:
Also did you find that there a lot of single terminal plugs and spade connectors that don't connect to anything? A few examples:
polsta
dont worry about ones not connedcted if everything works, there are a few like that, for things you may not have, ie obc ,oem alarm, probably cruise control etc etc, as long as everything works youl be fine
