Good cure for body roll?
joeseth
My rear wheels rub on the arches when heavy cornering. I want to stop the body rolling so much as I don't want to change wheels or ride height or anything like that. A friend suggested stiffer shocks? Is this the best option and which would be best?
'89 Lachsilver m42 coupe - Sold
'92 Laguna Green Convertible M50
'97 e36 328i sport - Daily
'89 Alfa Romeo Sprint cloverleaf
scjimbo
Inner or outer arches?
Why not roll the arches? Do a search on You-Tube; you can use a rolling pin or similar.
joeseth
Inner, they are rolled as much as poss and I like how it sits. just want to stiffen it a bit more so that it doesn't rub. Not sure what's best, uprated shocks, arb, stiffer springs, or some kind of rubber bump stops in the spring which I know some people use.
scjimbo
If it's the inners why don't you use spacers rather than trying to make the suspension stiffer and totally screwing your handling characteristics?
Sanchez
Theres your answer, dont corner heavy.joeseth wrote:My rear wheels rub on the arches when heavy cornering.
joeseth
Oh and by inner I didn't mean inside of he wheel just inside of the arch. Suppose it can't really rub on outside thinking about it that way ha
maggspower
- Turbo Farmer Tractor Driver
Uprated anti roll bars: "does exactly what it says on the tin"
Contact: theengineshedonline@gmail.com
joeseth
Yeah makes sense I just don't have any experience of them on an e30 so don't know how much difference it makes. What's best and who has one for sale
maggspower
I have only used them for their handling gains, not to fit wheels/tyres that are too big. But they do cut body roll.
The gentlemen at H&R and Eibach both make fine examples of these. They are around £350 for a pair.
Easier fix, is to fit wheels/tyres that actually clear the bodywork
capnmchl
ARB's
Stiffer springs
Move all possible weight inboard to reduce roll
^ What DanThe said
Stiffer springs
^ What DanThe said
capnmchl
ARB's
Stiffer springs
^ What DanThe said
Stiffer springs
^ What DanThe said
joeseth
Nah that's too easy, I like a challengeDanThe wrote:Easier fix, is to fit wheels/tyres that actually clear the bodywork
suchy
- True Zone Relic
The clue is in the name...maggspower wrote:Uprated anti roll bars: "does exactly what it says on the tin"
milescook
Forget all that, you need some kind of magic bar with "anti-roll" properties built in. I have one RARE sat in my shed yours for £1234.56p ;)suchy wrote:The clue is in the name...maggspower wrote:Uprated anti roll bars: "does exactly what it says on the tin"
Also please help the race budget by watching some videos
https://www.youtube.com/cookracinguk
Black_Potato
The problem is that with no other mods you will quite likely just trash the ride quality and make the car very tail happy.
3x S14 Rightness....
assassin
Cure for body roll?
Have you tried the Slimfast Plan?
joeseth
I'll have to try that one :p
