Wet floor - RHS
Shaheenk
Post Tue Oct 01, 2013 2:49 pm
HI Guys
So after much work on the car I am finding that with enough of a downpour I am getting a trickle of water up against the firewall . I have checked the Elephant trunk and confirmed this is all dripping out where it should.
There was a crack on the firewall but this has been sorted as well.
I cannot see anywhere else this could be coming from and have had a light up under the dash.
I think (may be wrong) that the leak could be from 3 sources.
1. Pedal box - Where it attaches to the firewall, I know there is a gasket behind there, but how much of a mission is it to get to that gasket
2. Steering column mount - 2 nuts that I can see , undid both of them but still unable to pry the damn thing away from the firewall, what am I missing
3. Heater box - top end where it attaches to the front, I am not in the mood to pull the entire dashboard out to pull the heater. Is there a way I can reduce the amount of water that gets into the skuttle panel (block the vents or something ???)
Thoughts , predictions and votes on a post card
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue Oct 01, 2013 5:00 pm
Simplest thing to do is to pour water into the scuttle vents and look for drips in the dash. If you find drips, you've got a rusty bulkhead.
Sanchez
Post Tue Oct 01, 2013 5:08 pm
carpet out and talcum powder the inside where you think it leaks and wash the car.
The talc should have water marks from a leak.
Shaheenk
Post Tue Oct 01, 2013 5:20 pm
carpets are out so I can see the trickle , its right up against where the heater box is but right right on top , so I guess that's where the seal is .
This is Souf Africa , no rusty bulkhead confirmed when I did the blower motor.
