I'm getting the feeling that my fuel gauge is lying to me quite a bit!!!
Although I think there may be a problem developing else where and the car does seem rich, the fuel gauge is now taking the peepee!!!
Since I've realised I'm filling up a lot recently, I've noticed the gauge seems to vary in position by up to 10mm at times!!!
I can be idling with just over quarter of a tank and when I floor it, I've suddenly got nearly half a tank again!!!
It does also seem to fluctuate a bit sometimes when just idling (by 3 or 4mm sometimes!!!)
So I'm guessing some kind of dodgy earth or loose connection somewhere???
Where should I start looking???
I've also changed the clocks on this car in the past, but have only just become aware that there is a difference in them for different tank sizes!!! Could I have used the wrong one??? How can I tell???
The car is a 1990 M20 Touring (was 2.5, now 2.7!)
Think the replacement clocks I used came from a 320 touring, but I wouldn't want to guarantee it!!!
Cheers,
Rob.[/code]
Fuel gauge.....
miniblob
327 Touring with bass!!!
BHadley
Have you Checked the brass nut on the back of the dash cluster where the fuel guage sits? Heard it can work loose and cause issues.... Worth a look
miniblob
Will check that first when I get a chance!!!
Strangely been behaving ok since I posted that - until this afternoon!!!
Epyon85
Mine does a very similar thing, initial start the gauge will read say, half a tank, after a short drive like a grandad the needle can shift as low as a quarter, if I give it some beans it can return right up to or greater than the previous half full reading!
BMW E30 M50B25 Turbo
parkin10
my fuel gauge changes as I go round corners goes up one way emptys the other
theres two senders in the tank I think one will not be working properly
I can gauge fuel usage well enough as it is though
miniblob
Mine was a nightmare yesterday and then fine again today!!!
Taken from the wiki:
So on realoem - is that parts 5 & 9 below???
Are they not the same part number and does anyone know if they really are that expensive???
I was hoping they would just be a few quid each so I could just replace them to either sort it, or rule it out!!! (I know this will upset several people who will say test before you replace anything - but I'm very short on time to play with this at the moment!!!)
05 SENDING UNIT ASSY METAL TANK 1 16141152266 $138.71
09 SENDING UNIT ASSY METAL TANK 1 16141179720 $138.71
I'm worried I'll test them and not find a problem, as mine seems to be quite intermittent!!!If your fuel gauge is flickering, a broken sender is a common culprit. To check, pull the plug off them, one at a time, and short together the relevant pins in the plug, with less than half a tank of fuel on board. When the faulty one is shorted, the gauge will give an inaccurate but steady reading. Conversely, when you short the good one you will get an inaccurate and still jumpy reading.
If the gauge is still jumping around with both senders shorted out, then the brass nut on the back of the gauge, or the wiring (unlikely), is at fault.
Text of that wiki article seems familiar!
Drive it for a week with each sensor shorted in turn if the fault is intermittent. The low fuel light should work as normal.
Two new sensors would be an appreciable percentage of the value of your car, and are totally unnecessary. A second hand one will be perfectly adequate - only a small percentage of sensors ever go wrong. I don't think I've ever seen one.
Tales a few minutes to fit a short on one of the senders, then you just use and drive the car as normal, apart from remembering not to run out of fuel.miniblob wrote: but I'm very short on time to play with this at the moment!!!)
miniblob
Hmmmmm, when should it come on???The low fuel light should work as normal.
Come to think of it, I've never seen mine light up on this E30 and I've had it below the bottom of the gauge (according to this dodgy gauge!!!)
Fair enough - I shall have to do some testing then!!!Two new sensors would be an appreciable percentage of the value of your car, and are totally unnecessary. A second hand one will be perfectly adequate - only a small percentage of sensors ever go wrong. I don't think I've ever seen one.
Just thought it might be a cheap part to replace, but as usual, I'm very wrong!!!
I'm assuming the fuel sender from a K plate 318i Cabby is of no use to me??? (As I have one sitting on the drive in bits!!!)
RH sensor is identical (remove it with the rest of the pump assembly still in place, or you will damage it). LH sensor is also identical, if it exists.
miniblob
Superb - I'll keep hold of that then!!!
Cheers Brian!!!
Cheers Brian!!!
Bertil
Hi guys!
I recently got a problem with my fuel gauge, it ain't the same as TS but I thought that hijacking this thread instead of making a new one would be better..
The problem I got is that the fuel needle just stopped working after I had been running low on gas, fill'd it up with like 19-22L, the needle goes up like normal. I went home and the day after the needle wont move more than just that mm when I turn the ignition on.
So do any of you have any clue what my problem may be ?
The car I am talking about is a e30 320i from 1987, and I'm from Sweden if that would matter.
Thanks in advance // Bertil
Bertil
Thanks for you answer!
I went out to try that, but my needle didn't go the way you described..
I made a quick vid to show you what I mean:
Will's instructions on bridging wires aren't too clear on what he meant.
You will have three wires in the plug to the sender - one plain brown, one brown/grey and one brown/green.
If you link the plain brown to the brown/grey, then the low fuel warning light should come on.
If you link the plain brown to the brown/green, then the gauge should go to full with the ignition on.
Your vid. looks like you may have connected the brown/grey to the brown/green.
