Two pin m20 starter motor
Gregg83
I've got my M50 in, up and running fine (eventually), but I fitted the earlier two pin M20 starter and didn't connect the green/black wire, which I have now found out powers the windows, mirrors, and heater blower. This may be a daft question, but where is best to connect this wire now? If anyone could let me know i'd really appreciate it!
Connect it to the inner 8mm stud on the solenoid - the terminal that has a strap or braid going to the motor itself.
Gregg83
Done, and works perfectly! Thank you Brian!
