s50b32 e30 325i sport tech 1
hybrid
Tue Jul 05, 2011 10:48 am
On the quest for lower lap times decided to do something about the seats.
Ill post what the new road seats will be later, theyre not quite done yet.
Recaro SPG Race Shell
Modified and lowered Recaro rails
Recaro side brakets
Willian 3 inch harnesses.
This is before lowering.
After
This is the next mod
Bonus points to who can guess what it is .. you need to be accurate. :)
Tue Jul 05, 2011 10:52 am
Looks potentially like a single wiper conversion..
ACS/Hartge or whoever it was who did them?
hybrid
Tue Jul 05, 2011 10:55 am
Correct .. I scored this from an original Warstiener DTM car. It weighs nothing.
Tue Jul 05, 2011 10:59 am
Nice! :cool:
hybrid
Thu Sep 22, 2011 5:20 am
Seats and new oil cooler
The stock BMW cooler was pissing me off so I replaced it with a big ass Earls oil cooler / lines (under number plate)...which extends up to the top of the bumper with the blue lines through the grill. Its all isolated and rubber mounted as not to twist the cooler frame
You can kinda see the brake cooling ducts.
All set for summer of time attack
Thu Sep 22, 2011 2:31 pm
lovely seats those.
how long before the pass one gets a brown stain winkeye
martinpallot
Fri Sep 23, 2011 9:28 am
For those interested, those single wiper conversions originate from a fiat uno, I have same in my car. Great car BTW!
hybrid
Mon Sep 26, 2011 4:20 am
You can use the Fiat ones too however they weigh a bit more than these magneti marelli magnesium ones.
mani
Mon Oct 03, 2011 9:15 pm
crazy !!!
H35-IAN
Thu Oct 13, 2011 6:24 pm
this has to be one of the best s50 projects ive ever seen hats off to you :) where abouts u from ??
bmw 328i sport e36 :)
badger88
Sat Dec 17, 2011 4:36 pm
holy shit im just doing some research cause i really want to do this conversion im actually gathering some bits together as i write this, but having seing the actual work that is involved i am having second thoughts lol think its a bit much work for a basic mechanic that will be attempting to do this conversion on the drive way. well done mate fantastic work :D
"IF It's not right it's wrong"
lyricalnut02
Sat Dec 17, 2011 4:45 pm
amazing work mate, great build.
325i Sport Tech 1 - R.I.P
E30 addict.
hybrid
Wed Jan 11, 2012 8:22 pm
updates:
So been a bit busy ordering some new stuff.
New Oil housing with the elusive pressed in Oil Thermostat, yes you have to buy the whole housing just for this one bit. My old one is poked shut.
And while im at it I installed a new Ratiometeric 0-100psi, 0-5 volt industrial grade pressure sensor (Thanks to conrad for help locating one)
This will eventually connect to my new GPS datalogger project :) (watch this space)
Just sitting it in the housing, will seal with alloy washer once locked in.
hybrid
Wed Jan 11, 2012 8:23 pm
Nothing too special .. but got a second set of race wheels and a supply of slicks.
Wheels: BBS RX 17x8 et38
Test fit on car
Caliper Clearance for BBK
.. slick supply .. went halves with james
hybrid
Been working on the brakes recently to hunt out a few issue with over heating
Changed out the pads to something a bit more race orientated and less best of both worlds
Followed Ollies Gee's path and went with the V8 Super Car / NZv8 route. Performance Friction Pads
Type 81 Medium Compound
Bevelled edges for noise reduction, my neighbours will probabaly love me now instead of the screaming from the other pads which normally happens on warmup
Also thanks to Ollie McDermott working on some prototypes, these are back from the laser cutters and currently being welded up. All alloy light weight.
hybrid
Tue Dec 11, 2012 6:33 am
More updates:
:) -- this is actually leading to something :)
small update ... kind of pointless and expensive to do, but i'm a details guy :/
Before
After: Genuine recover
Roof rust be gone
It was pretty bad if some of you remember ... decided it was more than time to get something done about it.
Rocking the RXs for the time being while I put it back together :)
Wet weather weekend stuff rules :)
So starting to put the final touches on the car of all those little bits that have annouyed me. Will have some more interesting updates come soon but for now you have this :)
I decided to splash out on some new OEM replacement pre-fl tail lights. Will just thank Jon the Pom for pointing me in the right direction for these.
unboxing
Old tail lights doing what all e30 tail lights do best and cracking. Still not bad for 26 years old. The right side had spider webbed pretty bad
And the left side had the usual inner piece fall off. Its so strange that this combo always happens to every car?
Removed the old lights and cleaned up the area the new sealing gaskets would sit.
After messing around with the wiring and plugs which had started to loose their bite on the terminals .. here they are installed! :)
bmw335icoupe
Tue Dec 11, 2012 6:16 pm
...where is this miracle making garage, please? :D
hybrid
Tue Dec 11, 2012 10:03 pm
bmw335icoupe wrote:...where is this miracle making garage, please? :D
Haha ... Auckland new zealand
hybrid
Tue Dec 11, 2012 10:40 pm
bmw335icoupe
Tue Dec 11, 2012 11:33 pm
in that case people in New Zealand are very, very lucky. :D
hybrid
Fri Jan 11, 2013 1:00 am
A rather cool oppertunaty came up to purchase a brand new e30 m3 260kph speedo. I almost passed this up but a couple of things made sense. My speedo's odometer had just crapped out and stopped reading K's and new units dont come a long for this price very often.
Big thanks to Dylan for this as dylan was replacing a needle in his car and didnt need the whole unit. (long story)
Anyways, photos.
Unboxing
Inside the box
Pulling apart the cluster and removing the old Odometer
Installed the new e30 m3 260kph odometer :)
Seriously .. I hate reinstalling this dam bitch nut!
and all installed ready to click over to 000000 :) Everything works perfectly, including my rev gauge was giving issues as it was down 500rpm, this was because of the needle was out on the spindle.
hybrid
Sat Sep 21, 2013 9:08 pm
Some nice shots while I was out this winter.
zaust
Zone day release
Sun Sep 22, 2013 10:32 pm
Nice tripod :)
But seriously, been watching and loving.
M30 Tech 1 Touring on gas.
E30Kop
Tue Oct 01, 2013 12:44 pm
Wow this is one AWESOME build!!
I have that motor in a more door M3 but can only imagine what it feels like in the raw E30!!
