M30 Emmissions failure
E30_Jatt
Post Sat Sep 14, 2013 5:57 pm
Couple days ago I finished my m30 conversion and today I took it for a MOT, it failed on the emissions test. Below are the results:
RESULT MAX
Fast Idle Test Fail
CO Level 0.23 Pass 0.30
HC Level 269 Fail 200
Lambda 1.09 Fail 1.03
Second Fast Idle Test Fail
CO Level 0.63 Fail 0.30
HC Level 586 Fail 200
Lambda 1.06 Fail 1.03
Natural Idle Test Pass
CO Level 0.25 Pass 0.50
Overall Result FAIL
what do you guys reckon I could do to bring down the emissions?
jimbom30cab
Tech 1 freak
Post Sat Sep 14, 2013 6:10 pm
Give it a good thrash with some redex before the MOT
Add some sea foam
Or
Take it to a more 'friendly' MOT station
As it looks like its running rich it could be an air leak so check all vacuum hoses
Bristol_Jer
Post Sun Sep 15, 2013 3:49 pm
Those results look like it was tested as a 1992 onwards car. What year car was the m30 from and what year is the car you've put it in?
Post Sun Sep 15, 2013 3:54 pm
The limits for your car are 1200 ppm HC and 3.5% CO.
Your MOT tester is unfit to do his job.
The age of your car and the car that the engine came from are not relevant.
Take it back to the tester, educate him in how to do his job, then demand your pass certificate.
Edit: The South African 335i doesn't appear in 'the book' does it??
Edit to edit: Still wouldn't be an "exact match".
E30_Jatt
Post Mon Sep 16, 2013 1:42 pm
I also thought that the emissions test results weren't right, I have had a look at the emissions paperwork again, it seems it has been tested as a 1993 316i with a lambda sensor, this is what my car was originally from the factory.
Do I tell the tester to retest the emissions as 3.5 engine without a lambda sensor? I am just worried about him getting funny with me over the matter.
Post Mon Sep 16, 2013 1:56 pm
Refer him to the flow chart "Exhaust Emissions - Spark Ignition - Passenger Cars 1 August 1992 to 31 August 2002" at the end of section 7.3 of the Inspection Manual for Classes 3, 4, 5 and 7 Vehicles.
http://www.motinfo.gov.uk/htdocs/m4s07000309.htm
Also, point him towards the nearest branch of Specsavers. There's something seriously wrong with his eyesight if he can't tell the difference between a little 1.6 M40 and an M30 anchor.
Post Mon Sep 16, 2013 2:03 pm
A dodge you could try, is to disconnect one or two of the injectors, and run it through the test as a four or five-cylinder engine.
It worked for me on a 320i that had a stripped spark plug thread. :wink:
Post Mon Sep 16, 2013 5:54 pm
No dodges required. It has been tested to the wrong standards. End of.
