Hi
I have recently purchased a 1986 316 manual and it is completely standard with 14" trims on. I would like to put alloys on it whilst still maintaining its originality. I am just wondering which alloys would be the best option. I was thinking BBS RS alloys but I do not want to lower the car.
Any advice or input would be greatly appreciated.
New Owner Wheel Advise
alexdejonghe
Depends on budget & taste...
If you're sticking with originality then look no further than standard 15" BBS, 16" genuine alpinas or 14" bottle tops...all of these will be a big improvement on standard hubcaps. See this guide below;
http://www.e30zone.net/e30zonewiki/index.php/Wheels
james158
Right okay, thanks for your help. Do you think 16" BBS would be too big?
jmc330i
16" BBS would be fine, but not cheap at all!
I'd stick with the tried and tested 15" BBS - they look good, suit the car and won't break the bank.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
james158
What style BBS would you suggest? I was thinking BBS rs, would it need to be lowered or will it sit fine on standard suspension? However I think my wheels are 4 stud so not sure if they will fit.
MattTheHat325
BBS rs's are expensive split rims, depends how much you are looking to spend? They are easier to find and cheaper in 15" form, if you are wanting an original look, 15" rs maybe 7.5" or 8" wide with 205/55/15 like standard 15's. this combined with something like a 30 or 40mm drop on h&r or eibach springs and you should end up with a very oem looking yet pretty e30!
Bear in mind you'd want to budget at least £1k for rs's, tyres and springs, although you may come across some bargains on here! You never know what these guys have got stashed up their back passages
