rear diff cluncks
thehotairballoon
Post Sun Jan 08, 2006 7:17 am
as i select reverse gear aloud clunk is heared and felt from the diff sometimes. any ideas
telski789
Post Sun Jan 08, 2006 10:33 am
theres a mount under the car which bolts your prop shaft to the car with 2 13mm bolts,mine came loose once and the looser they got the more it clonked,bought a new mount and when i got the car in the air i could see it was just loose,gave it a good tightening with some loctite,jobs a gooden! if its from inside your diff,then i aint got a clue,seems unlikely to be that,diff trouble is normally a continuous sound,not an odd knock,Tel
stevetigger
Post Sun Jan 08, 2006 4:36 pm
100% propshaft, loose or missing bolt
