So car drove fine for about a 15 min drive then i stopped for less than 5 mins turned engine off but upon restarting the car would barely move no matter how much i put my foot down, limped for a bit then it suddenly came back to life after about a mile of not getting above 10mph after that i could feel it loosing power and regaining it again any ideas ?
Not sure if anythng to do with it but i could hear a Belt squeeking as power was lost ? Having cam belt and water pump done tommorow so will be on a ramp if theres anything that can be looked at while there ?
I love a story sorry lol
Struggling to drive
BenHar
And what is this car?
Ben
Ben
Topblag
How much knowledge of the engine compartment contents do you have ?
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
I think he has a 320i cab.
Check the usual culprits - dodgy engine-to-body earth strap, worn spark plugs/rotor arm/distributor cap, blocked fuel filter, etc.
Also check that the throttle pedal actually opens the throttle body when depressed - the cable may have stretched!
Davebmx
Thanks I'll have a go through and ye 320 cab
Davebmx
So while on the ramp allot has been discovered
Ive just bought the car with 11 months mot and weve found the brake and fuel pipes heavily corroded, ns and os steering rack gaitor split, front arb link needs replacing, abs wire cut... It goes on
So now ive had to report the test centre to vosa and its having a re test and going from there
JF008
bastards!
Nobby_N
They will get away with it as its been 1 month since test, the car could have been in Scotland for a month hence all the rust and corroded pipes lol
hennared323i
K N O BNobby_N wrote:They will get away with it as its been 1 month since test, the car could have been in Scotland for a month hence all the rust and corroded pipes lol
Davebmx
its 1 month on mechanical 3 months on corrosion so vosa told me im ok ive spoke to the garage that done the mot and they got a bit scared when i said i was ready to report to vosa and have offered to come and take the car away for a little more than i payed so i dont report them...
this is my first e30 and i loved it for all of 2 weeks its not gone yet there ment to be coming this wednesday so ill be in the market for a new one which hopefully will be a bit more safe.
TPS
There are plenty of decent E30s around, take your time, & you'll find one.
Sanchez
Old cars are a learning curve, and yours has started quiet steeply.
You probably know more about an e30 in 2 weeks than some learnt in 2 years.
