now i have everything in place bar the p/s pump and exhaust and just wanted to here the engine crank over make sure things were algood.
i had already cut the brown wire from c101 plug pin 20 as was on engine loom and left for now,connected battery now the car won't crank off the key but will if i bridge starter.happy that it cranks but not as happy because i can't turn over with the key?
also upon my find removing the chavvy amp cables i came across this wire and is a bit worried to why this has happened and what it does
please someone as i'm about to give up on this completely
