bottle tops replaced with bbs crosspoke
thehotairballoon
all fine car drove in a straight line with bottletops and steering wheel was dead straight. fitted bbs crosspokes and now pulls to the left. the steering is not straight any more. any ideas
orangecurry
if you now have 15" BBS, I have experienced something similar - the 15" BBS are 7J, whereas the 14" botts are 6.5J, so you might need tracking doing... I also have the same thing going from 15" 7J BBS to 16" 7.5J Hartges as well
not so much the steering pulling (a tiny bit) but definately the steering wheel
MONSPORT42
What tyre sizes before and after? And are the new ones all new/good? Could be as simple as balancing.
YOUR LEFT FOOT'S FOR BRAKING
Are they same type/size/pressure on the same axle?
thehotairballoon
had 14" 6j bottle tops
now 205 55 15 tyres 15" 7j
front tyres the same and rears tyres the same
30 front 28 rear pressures
k130
My owners manual states 2.0bar front and 2.2 bar rear -but the bigger, fatter wheels will exaggerate any tracking errors you may have had before...
orangecurry
balancing won't affect either where the steering wheel is when going straight, or pulling to one side
if you are not going to be swopping back to the 6.5Js, I'd get the tracking checked - costs nothing. If it is out then you'll be saving your tyres anyway, even if it's not the cause of your problem.
I know it's difficult, but try and go to a 'good' tyre outlet. A few years back I did a tour of tyre places with my mums car, as she said it felt funny; I thought it was ok, but I went anyway; most of the tyre places said
' tracking is out; needs doing...' without spending enough time or looking up the specific cars data
I went somewhere else, he took his time, looked up the cars toe-in etc and eventually said 'doesn't need doing'
I trusted this guy because of his attitude...
thehotairballoon
car never pulled on bottletops steering wheel was straight. now pulls left and steering wheel is not straight
