on idle it idles around 1300-1400 rpm which i know is high but if i play with the throttle cable and loosen it so it goes down to around the 600-700mark it cuts out,
also when i accelerate it seems to have hesitation when i change gear as the revs dont seem to drop very quick when put clutch in? ,
any ideas guys on what this could be? , or anything i can do to try sort it out, bit embaressing if pull up to lights and car just cuts out, :\ , starts fine but just not sure what it could be,
ive cleaned throttle body, checked the elbow from the throttle body for holes / rips just not sure what it could be
any help would be good:) , or if anyone is down plymouth way and fancy a look would be appreciated!
rough idle and sometimes cut out,
Try letting the car idle with the engine warmed up, and spraying WD40 all around the inlet manifold gasket (from above and below); if it briefly raises the idle speed then you have a gasket leak.
Also check all inlet manifold/TB hoses for splits.
E30-Doc
sounds similar to when my Throttle position sensor went. This would be worth a check
( i did all the usual hose leak chasing, and ICV cleaning, and replaced all my gaskets to find it was the TPS all along)... things ran a lot smoother after all the work
If it wont idle with the throttle shut you clearly have vacuum/secondary air problems
