Any tips or hints on how to get this bloody assembly out?
Wiper motor and blower fan top covers have been removed already.
TIA
Windshield wiper linkage removal
- **BANNED**
I assume that you have removed the black plastic vents around the o/s wiper spindle and above the wiper motor?
And dis-connected the linkage from the motor?
After that,there's a bolt at the o/s that supports the linkage and it should fiddle out,you may have to remove the motor first and slide it out the n/s,its been a long time since I had one in bits!
Youth is wasted on the young.
hennared323i
Everything has been removed/disconnected - mech seems to be hanging up where spindle comes through scuttle panel on drivers side.
- **BANNED**
Have you tried operating the dis-connected mech to compress it?
Seem to remember it all needed to come on the passenger side.
Keep fiddling,it will come out!
hennared323i
Will have a further play this evening.
Cheers fella
Cheers fella
aimlessrock
it does come out but you have to expand it full and feed it out from memory..i recall mine was a bit of a git to remove but a bit of lateral thinking and turning the rods as i pulled them out..something like that..have a play, will get it..
E30 320i Convertible (1989)
190 Mercedes (1988)
190 Mercedes (1988)
