speedo
burnout
Post Sun Aug 25, 2013 7:57 pm
hi all currently converting my 318i auto to m20b25 manual one problem that i have come across is that speedo i removed from auto box i can't find a location on the manual unit.
gearbox in question is a getrag 260,all i can find is the reverse switch on the side.
hopfully someone can help :)
E30 325i se
gromgsxr
Post Sun Aug 25, 2013 8:06 pm
My car speedo is driven off a sensor in the rear diff
TPS
Post Sun Aug 25, 2013 8:09 pm
gromgsxr wrote:My car speedo is driven off a sensor in the rear diff
+1, they all are?
burnout
Post Sun Aug 25, 2013 8:10 pm
i've got plug that goes to the rear diff too,so a bit confused lol
E30 325i se
navi
Post Sun Aug 25, 2013 8:37 pm
as you car was an auto the plug you have might be for the inhibitor switch if this is said plug you will need to sort it out if not it will not turn over when you try starting it.
burnout
Post Sun Aug 25, 2013 8:55 pm
navi wrote:as you car was an auto the plug you have might be for the inhibitor switch if this is said plug you will need to sort it out if not it will not turn over when you try starting it.
the plug in question is like 2 dots on the plug end
ok thanks if said it is how do i get around that problem?
E30 325i se
navi
Post Sun Aug 25, 2013 9:37 pm
a photo of said plug may be of great help as 'two dots' could mean anything?by this do you mean pins/contacts?
basicly all you would need to do is bridge them.
but iam sure someone on here has done this in the past on an e30 and can help a bit beter than myself,but thats basicly how you get around/bypass a inhibitor switch. it has court many people out over the years ive been working on cars as to why the car wont turn over!
burnout
Post Sun Aug 25, 2013 9:50 pm
ok thanks i shall get a pic in morning of the plug and post it up
E30 325i se
