Quick one,
The headlamp level adjuster underneath the headlamp swich, for correcting for heavy loads/towing - do I need this to be operational for an MOT? Or do the headlamps just need to be aiming correctly?
Cheers guys.
Headlight level adjuster
Headlamps aimed correctly is all that matters. There is a manual adjustment facility where the hydraulic actuator attaches to the headlight.
Your hydraulic headlight levelling is undoubtably dead, like 99.9% of so equipped E30s
milescook
Fairly sure myself and many others don't have one? So you could always pull it out?
Also please help the race budget by watching some videos
https://www.youtube.com/cookracinguk
Motorhole
Yeah that's the plan. It's hanging loose in the passenger footwell right now and I'd rather just bin it.
hennabm
Only needs to work if you have HIDs fitted. The other option, as mentioned, is to remove it if HIDs are fitted.
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
'11 X3 3.0d SE
'89 240 DL Estate
harry_p
As its not self levelling surely its irrelevant hids fitted or not, so long as the lights point where they're supposed to when presented for the test?
cheers,
harry
harry
