http://www.turnermotorsport.com/showpro ... k-stop-kit
have seen the above kit on turners site but with shipping comes to £50
Does anyone uk based do the same kit?
Motorsport Steering Rack Stop Kit
ajay
CA automotive get them in from turner in the usa, they done an order for me a while back. I think they charged me £30 inc postage to my door, Roy at CA did order more than one set and did have at least one set on the shelf in the uk. They are different for e36/e46 racks, and on the kit i ordered (e46) the spacer are different colours as each end is a slightly different size. When fitted i found it restricted the steering too much and got a perfect balance cutting them in half. Berore you ask, Dave the goat had similar issues and i gave him the other halves. You could just get them machined up at a local machine shop, they are just a round disc that limit the steering according to how wide they are. I ended up with about an 8mm disc each side. GL
crossie
thanks will speak to CA automotive
Am sure I had read that you could cut them in half
only reason I need them is that the mot chap says my wheels touch the wheel wells - better having them fitted that damaging a tyre.
crossie
ordered anyone want the other half?
davethegoat
The spare halves worked a treat Ajay! Cheers mate!
ajay
Works a treat for me too Dave, no worries!
HairyScreech
edit - ignore that wont help if you only need a small amount of lock reduction.
You just need a man with a lathe and a lump of nylon
