Hi All,
The radiator fan has seized on my M52 conversion, the car was converted by another zoner so I'm not really familiar with what has been done. The fan is from a e36 compact and seems to be creatively "hung" in front of the radiator. It got very hot, smelt of burnt plastic and will not spin freely.
The question I have is what is the best fan to replace this with. Hopefully my local garage will be fitting it, but I'm concerned it could be challenging their knowledge. Any advise on what is involved with swapping the fan would be much appreciated.
Many thanks in advance.
Tony
EDIT: Is this the fan I need?
http://www.gsfcarparts.com/936bm0120
M52 fan help please
hongkongfuey
- Mad-tango-geezer
I used a volvo setup Im not great with wiring and did it myself. You could use e30 aircon fan
with cars like mine,
If thats the case stay away!pony2 wrote:Hopefully my local garage will be fitting it, but I'm concerned it could be challenging their knowledge.
what is the fan in the link supposed to fit?
pony2
Hi Dan, Alas I don't have much choice which garage, but I only need a temporary fix to get it to someone who knows what they are doing.
Forgive my ignorance the fan I listed is a e36 from gsf which is nla, just trying to figure out what the best replacement is.
Thanks for the replys.
Tony, IIRC , all E36 fans are 'pullers' that fit between the rad and the engine, they will not be suitable for your application as there is no room. Any pics of what you have fitted ? cableties/ scotchloks and all, don't be shy !pony2 wrote:Hi Dan, Alas I don't have much choice which garage, but I only need a temporary fix to get it to someone who knows what they are doing.
JF008
wouldn't an universal slimline fan be a good thing? Space saver I would have thought.. Are they rubbish?
pony2
Thats an aftermarket universal fan, looks like you also need a new radiator as its falling to bits. Does it run off a rad temp switch or is it an ignition on full speed ahead affair?
Its fixed to the radiator by plastic fixing straps, a bit like cable ties. The fans are not terribly bad, but if its on all the time it will be getting hot and burn out a lot quicker than normal.
Ive fitted these to a few conversion and they are ok - http://www.ebay.co.uk/itm/200519242706? ... 1423.l2649
Airflow is the key, a corroded/blocked radiator will only help the fan burn out quicker
pony2
Thanks Dan, I believe it runs of a temperature switch - comes on when the temp gague is half way. Cheers for the link.
Yeah the rad does look a bit gone, add it to the very long list of things wrong with this car.
SteSE
- Heading for the Naughty Room
You can (could?) still buy the aircon fan mounting kit from BMW for not alot of money. If buying a second hand aircon fan make sure the resistor for lo / high works as mine only comes on at high!
shedrool83
Thats similar to me set up.DanThe wrote:Thats an aftermarket universal fan, looks like you also need a new radiator as its falling to bits. Does it run off a rad temp switch or is it an ignition on full speed ahead affair?
I have a new rad , 80/88 fan switch and 80 thrmostat.
My fan comes on at just over halfway when idling from cold but if i go for a long'ish drive it doesn't come one until 3/4 mark which is a bit scary.
