Running rich after throttle body change
oomz1975
Post Fri Aug 16, 2013 8:09 pm
Replaced my throttle body, along with the tps, with a spare one.
The original developed a coolant leak.
Now the car seems to be running a little too rich...
Car was running perfectly before the change.
Any ideas?
1990 325i
jimbom30cab
Tech 1 freak
Post Fri Aug 16, 2013 8:27 pm
is the TPS set up perfectly, they are quite fiddly to get right
if so then i'd check the TPS with your multimeter
oomz1975
Post Fri Aug 16, 2013 10:14 pm
jimbom30cab wrote:is the TPS set up perfectly, they are quite fiddly to get right
Good shout...
I'll check back later. Cheers :)
jimbom30cab
Tech 1 freak
Post Fri Aug 16, 2013 10:35 pm
I've found it needs to be exactly right between just before the click and not opening the butterfly, it's a very fine adjustment.
Worth also checking it's not full of oil and give it clean with something like carb cleaner etc
oomz1975
Post Fri Aug 16, 2013 10:41 pm
jimbom30cab wrote:I've found it needs to be exactly right between just before the click and not opening the butterfly, it's a very fine adjustment.
Thanks....
I'm sure it's just adjustment, I had cleaned it prior to fitting.
oomz1975
Post Sat Aug 17, 2013 7:33 pm
Yep, adjusted/fiddled with the tps made it alot better.
Still get slight flats spots in the higher rev range, but overall idles how it should now.
jimbom30cab
Tech 1 freak
Post Sat Aug 17, 2013 8:30 pm
