M42 Chain and Tensioner parts
Looking for genuine BMW parts at discounted prices? Try here!
baggimodo
Post Sun Aug 11, 2013 1:20 pm
I'm going to change the timing chain, tensioner and guide rail on my M42 but I can't work out which guide rail I need from RealOEM, do you have a price for all the parts required to change the chain, guide rail and tensioner?
Thanks in advance
Cotswoldbmw
Post Mon Aug 12, 2013 7:45 am
Hi can i have the last 7 digits of your chassis no? Thanks.
regards
Paul.
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
baggimodo
Post Mon Aug 12, 2013 9:08 am
the m42 wasnt originally in the car! :( what other identification numbers would help?
Cotswoldbmw
Post Mon Aug 12, 2013 10:27 am
See if you can get the chassis no off the car it came from. Thanks.
regards
Paul.
Cotswold BMW Parts
01242 335365
baggimodo
Post Thu Aug 22, 2013 2:48 pm
Havent been able to get the chassis number though I do have the number plate, is this going to help? Its H868 RKG
I've found this list of parts on another website so these might be a good indicator.
Lower timing cover gasket set 11141721802
Front profile gasket 11141247837
Rocker cover gasket set (only if the existing ones are old - they will withstand removal while the rubber is soft) 11121721876 profile gasket, 11121721475 spark plug chamber seal - lollipop shape, 3 off 11121721476 spark plug chamber - O shape)
Timing chain 11311247160
Crankshaft sprocket 11211247338
Camshaft sprockets (2 off) 11311721887
Front crankshaft oil seal 11141439570
Thermostat housing gasket 11531721172
Tensioner guide rail 11311727342
Guide rail 11311247470
your help would be greatly appreciated.
Sham
Willeh
Post Tue Aug 27, 2013 12:07 am
I'm also interested in this, I'll PM you too Mr. Cotswoldbmw sir.
Cotswoldbmw
Post Fri Aug 30, 2013 10:30 am
This is a bit of a tricky one, not knowing the engine details, not knowing exactly what items you will need to do the job completely.
if you give us part descriptions or part numbers then we can always quote you but as always if parts required are not standared fitment I will always ask for a list of part numbers required, this might sound a bit over the top but a couple of times in the past we have quoted for items which have then been ordered which were incorrect, it gives you delays in getting it right and can cost us in returning items to BMW
Cotswold BMW Parts
01242 335365
cjdonny
Post Thu Sep 12, 2013 3:16 pm
Hi I want a price for the same so can you use my vin number
Wbaaf92000ee47547
Engine no
01557122
318 IS
baggimodo
Post Fri Oct 18, 2013 8:22 am
Hey guys, could you get prices for these based on cjdonny's VIN?
Seems like these are only available from BMW so going to have to bite the bullet soon
TPS
Post Fri Oct 18, 2013 8:54 am
My Chassis no. is EE47233, if you need it
