after selling my e30 last year i ended up with a e36 m3 evo coupe .
the car is a bit rough around the bodywork but running gear is good , i keep thinking about swapping everything over to a touring.
has anyone built one or know of one that has been built and wot if any problems were there ?
e36 evo touring ?
harry_p
I know quite a few have been built, but I don't know any specific details.
I have read that it's easier if you start with a 6 cylinder touring, although I'm not sure why, I'd have thought if you have got a complete donor car then you'd just be able to swap everything over.
The only thing bodywise i would suggest would be to get a set of m3 reinforcement plates welded in where the rear subframe bolts to the floor. M3s were the only e36s to get them as standard.
cheers,
harry
harry
jmc330i
It's been done numerous times I expect. I know of two in the south west.
Everything should just be a bolt in job, I wouldn't expect any issues considering you're starting with a complete donor. Just don't get rid of the 2dr until you're sure you've got everything out!
I'd definitely do it, tourings are much cooler than saloons/coupes and an M3 powered one with the M3 suspension/brakes etc would surprise a few people
One of the ones I've seen is a complete sleeper - 318i badge and even a modded backbox to only show 1 tailpipe. The only exterior mod is the M3 wheels.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
6 pot touring help with the wiring looms at a guess? or close to the m3's spec with traction, bigger rear brakes maybe?
monkey
thanks to you all for the info .
i'm not worried about the brakes ect as I have it all on the m3
one thing I did think of was getting the oil temp gauge to work as I think it was only m3 that had it .
Neilios
M3 dash would be installed in the tourer.
Do you wan a cheap touring shell, minus running gear?
AndyG
