need info on lpg milleage
markus_74
Post Fri Jul 26, 2013 1:24 pm
hello,
need info on m40 318i engine how far milleage per kilogram lpg ?
I think to convert my car with lpg and how is the safe and cheap convertion kit that I can do it diy?
Thank you
markus
Nobby_N
Post Fri Jul 26, 2013 1:34 pm
what is price per kilo petrol in Kudus, what price Gas?
Post Fri Jul 26, 2013 1:49 pm
Your car should do a slightly more miles per kilogram of LPG than it does per kilogram of petrol, since LPG combusts more efficiently than petrol in a spark ignition engine. BUT, since the density of LPG is around 0.5 and that of petrol is 0.7 something, this equates to a decrease of around 20% when both fuels are measured in litres.
LPG is inherently safe when compared with petrol, and the storage used on cars bares no comparison - flimsy metal or plastic container containing a volatile liquid that will form puddles around your feet and soak into your clothes if it leaks, compared with a bomb proof container, fitted with electrically operated shut off valves, containing a liquid that, in the unlikely event of it escaping, will blow away in the wind, and is surprisingly difficult to ignite.
A DIY single point mixer system is easy enough for someone with reasonable mechanical skills, and can be done in easy stages. There are no mods. to the engine itself - just a couple of bits to attach to the air meter/filter assembly, plus the bits required to store and feed the LPG to the front of the car, convert it to a gas (with a connection to the car's cooling system), and meter it to the air filter.
MrT8064
Post Fri Jul 26, 2013 3:13 pm
My E34 running on LPG does about 20% WORSE MPG. 25 on the computer usually means about 21mpg.
Post Fri Jul 26, 2013 6:26 pm
MrT8064 wrote:My E34 running on LPG does about 20% WORSE MPG. 25 on the computer usually means about 21mpg.
That's what I said! This is because you are measuring the fuel by volume (in litres), instead of by weight, which is a much fairer comparison.
markus_74
Post Mon Jul 29, 2013 3:04 am
Nobby_N wrote:what is price per kilo petrol in Kudus, what price Gas?
petrol 0.4 GBP and lpg 0.3 GBP
markus_74
Post Mon Jul 29, 2013 3:06 am
I haven't got the answer for mile per kilogram or mile per liter for m40 318i engine use LPG, any info? thank you
Post Mon Jul 29, 2013 9:08 am
Brianmoooore wrote:this equates to a decrease of around 20% when both fuels are measured in litres.
markus_74
Post Mon Jul 29, 2013 2:45 pm
ok thank you Brian
