anyone know how easy it is to get to the wiper motor,its got a fault where the blades dont go back to rest when you switch them off,im guessing theres a limit switch on the side of the motor
Also the headlights work on dipped and main but you cant make them flash by pulling the stalk back to you
any ideas? i thought maybe the switch itself but dont want to just dive in there and pull it apart in case its a relay or something
thanks
Matt
annoying little faults
320Touring
Hi matttt!
welcome to the forum
wiper problems are a fairly common e30 issue and can be relatively easy to fix....
have a gander at this guide to give you an idea as to what could be causing the problem
http://www.e30zone.co.uk/modules.php?na ... wipers.htm
MATTTT
know it would be the limit switch but that article is great and will help loads
thanks for the link post
no ideas on the headlights i was hoping that was another common thing
cheers
Matt
cheers
Matt
keith52
Possible the relay has gone but unlikely as main beam works
more likely the contacts in the arm have worn , easy replacement
Too cold to go out into the workshop and check for sure, but IIRC, the headlamp flasher works by earthing the bottom end of the relay coil to a short brown wire that earths through one of the dip/flash switch fixing bolts. Check this is making contact OK.
You realise that the ignition has to be on for the headlamp flasher, don't you?
MATTTT
u got me thinking now im home
im 90% sure the igition was on! lol
i will re check tomorrow
i recon the switch itself but only guessing
i will prob leave it until its a bit warmer anyhow
