The previous year I passed MOT with 0.27% CO (the AFM "adjusted" by this guy)
This year with my new AFM 0.15% CO
No air leaks found, what can be wrong?
If it's an untouched AFM, it does NOT need adjusting. It was set correctly at the factory, and if adjusting it makes an improvement, then you are simply masking one fault with another fault, and making diagnosis near impossible - one of the reasons there are so many E30s around running way below their true potential.sweep wrote:the afm needs adjusting to richen it up
