obc
WEEMANDANBRITTON
Sat Jul 20, 2013 9:41 am
does the obc retrofit kit from a 6 cylinder work in the 4 cylinder?
i have one for a 325i and want to put it into my 318 is but woundered if it would work?
dan.
Cloggy Saint
Sat Jul 20, 2013 10:17 am
It will work but you'll need to fit the correct coding plug to get accurate(ish) readings.
WEEMANDANBRITTON
Sat Jul 20, 2013 10:44 am
Cloggy Saint wrote:It will work but you'll need to fit the correct coding plug to get accurate(ish) readings.
is that the bit in the back of the computer? any idea which one i would need? ie: part number?
Cloggy Saint
Sat Jul 20, 2013 10:46 am
Yes, it's the white plug in the back of the unit, no idea on the part number though. Put an ad' in the wanted section and I'm sure you'll get one.
WEEMANDANBRITTON
Sat Jul 20, 2013 12:09 pm
cheers.
