m20b28 what pistons
gromgsxr
Post Sun Jul 14, 2013 12:59 am
Does anyone know which pistons from a face lift car will fit without the skirts being shaven either mahle or ks?
aceifty
Post Fri Jul 19, 2013 8:07 pm
the face lift block shoulsd have a number reading 25 6 k1
gromgsxr
Post Fri Jul 19, 2013 8:47 pm
Yeah I have a facelift block 25 6 k1 as you say. but I was under the osumption there was 2 different brands of pistons used either mahle or ks and one of the brand requires the pistons to have the bottom shaved to clear the crank counter weights.
aceifty
Post Fri Jul 19, 2013 9:02 pm
im using the pistons out of a 25 6 k1 block for my M20B28 build and if im right the 25 6 k1 block pistons a mahle and the ks pistons need the skirts shaven.
hope that helps
gromgsxr
Post Fri Jul 19, 2013 9:08 pm
Thought that may be the case if got the ks pistons with a bit of skirt on them, I think the mahle are pretty flat about the base of the piston.
aceifty
Post Fri Jul 19, 2013 9:50 pm
Stick with the mahleones if you don't want to shave the skirts
gromgsxr
Post Fri Jul 19, 2013 10:02 pm
Need to find a set in that case
aceifty
Post Fri Jul 19, 2013 10:10 pm
Didn't you say you have a block with 25 6 k1 on it, if so the pistons from that block will do. If you still need some i might have a set just need to find them.
gromgsxr
Post Fri Jul 19, 2013 10:36 pm
Iv got the ks pistons so would need the skirt skimmed if you do have a spare use able set of mahle pistons with the gudgeon pins about let me know
aceifty
Post Fri Jul 19, 2013 10:44 pm
You can use the pins that you have got or the ones that came of the 320 block
aceifty
Post Fri Jul 19, 2013 10:45 pm
Ill see if i can hunt them down over the weekend. Ill let you know
gromgsxr
Post Fri Jul 19, 2013 11:02 pm
Cheers dude
