All bolts removed from the box, brake cylinder disconected,
so is it just a case of prying up both pins to remove the rod/
Part No's 12 below.
http://www.realoem.com/bmw/showparts.do ... g=35&fg=05
Thanks, Rob.
Pedal box pushrod.
gooner1
- Out humping Reindeer
- **BANNED**
Both pin's should just pop out with no wieght on them.
The main issue you will have is folding yourself into a position to get at the blighters!
Youth is wasted on the young.
gooner1
Cheers Malc.
Shouldn't be a problem, dash, seats, carpet have all been removed.
- **BANNED**
Can you grab some decent photo's of the pedal box area,please?gooner1 wrote:Cheers Malc.
The grrrmachine is trying to build a clutch master cylinder replacement article for the wiki!
gooner1
Sorry, day too late.
