m52b28 e30
alangorst
Post Sun Jun 30, 2013 3:32 pm
hi all i have a e30 m52b28...first time having it out yesterday and its limitering at around 5300 revs. what could be the reasons for this?
Cheers Alan
rich318i
Post Sun Jun 30, 2013 9:57 pm
speed input to ecu 100% wasn't wired up
ajay
Post Sun Jun 30, 2013 10:37 pm
As above, have you wired the road speed signal to the ecu, the ecu needs to know how fast the vehicle is traveling. The symtoms you describe highlight this as a posibility, have you checked for fault codes? Check both the above.
alangorst
Post Mon Jul 01, 2013 11:22 pm
Cheers lads
tbone455ci
Post Sun Jul 14, 2013 12:35 am
Hi mate
Did you get it sorted? Im having a similar problem but not revving past 4000, well it splutters after 3000 to 4000rpm badly.
alangorst
Post Sun Jul 14, 2013 5:50 pm
Not yet no :( I'm goin for the speed signal thing that everyone has suggested but as far as I've got is finding out what wire it is from ecu. Maybe get to it tomorrow night.
tbone455ci
Post Sun Jul 14, 2013 8:00 pm
Hope you get it sorted mate. I been having probs for the past 2 weeks, with misfires which was camshaft sensor to missing which was a bad coil pack but the bimmer still not revving past 4000rpm
I think its different to yours? But I will let you know when I get it sorted & may help you :?
Try and contact DanThe, this man knows a lot and should be able to help you....
