325i Gearbox/Diff Oil
zd3bx
Post Sat Jun 08, 2013 4:09 pm
Going to change my gearbox/diff oil next week, so need to buy all the fluids now.
After reading this... > http://www.e30zone.net/e30zonewiki/index.php/Oil
I'm getting Fuchs Titan Sintofluid 75W for the gearbox and I don't know whether I have LSD or not, so would it be ok to go for Castrol 75W140 for the diff?
It's LS specific oil, but I've read that you can use them in open diffs too?
Advice?
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Jun 08, 2013 4:44 pm
No, it's the wrong grade for an open diff, which uses 75W90.
Work out what diff you've got, then buy the right oil. They make different grades for a reason.
**BANNED**
Post Sat Jun 08, 2013 5:36 pm
To check if you have an LSD or an open diff,raise both back wheels clear of the ground.Turn one rear wheel by hand,and ask your helper to observe which way the other back wheel is turning.
Report your findings for further help.
Youth is wasted on the young.
zd3bx
Post Sat Jun 08, 2013 6:05 pm
daimlerman wrote:To check if you have an LSD or an open diff,raise both back wheels clear of the ground.Turn one rear wheel by hand,and ask your helper to observe which way the other back wheel is turning.
Grrrmachine, yeah I guess you're right ;)
Thanks for the help daimlerman, but I've done a bit of Google'ing after posting this, so...if I spin one rear wheel in one direction and the other one goes in the same way, then I've got an LSD.
If the other wheel goes the opposite direction, then I've got an open diff.
Correct?
Also read about diff tags and found it on mine, but it's all rusted and you can't see anything, so it's pretty useless...
gromgsxr
Post Sat Jun 08, 2013 6:12 pm
That is correct
**BANNED**
Post Sat Jun 08, 2013 6:26 pm
Correct?
That's right,so now you know that,you can decide what type of oil to pour in...
BTW,remove the fill plug BEFORE removing the drain plug,better to have disgusting old oil than no oil at all!
zd3bx
Post Mon Jun 10, 2013 9:02 pm
Checked today, turns out I've got LSD :D
Ordered Fluchs Sintofluid for the gearbox and Castrol Syntrax 75W140 for the diff - a job for this weekend!
TPS
Post Sun Jul 14, 2013 2:32 pm
I used EP80/90 in my gearbox, when changing the fluid, hope thats ok
