darkchild
Fri Jul 05, 2013 5:55 pm
Washed it for the first time in about 4 weeks. :)
Went back later to move it into the garage and noticed a note on the windsceen. A neighbour had reversed into it. :(
At least they done the decent thing and left their details (had a few incidents in the past where people haven't!) so a trip to the bodyshop awaits.
smithysmith
Fri Jul 05, 2013 7:58 pm
Removed resealed and refitted a leaky pas pump, bled the pas system. Fitted a z3 short shifter and relocated the battery to the boot. Five hours all in.
Jimbob
Fri Jul 05, 2013 10:21 pm
Finished fitting my big brake kits, upgraded to the 750 master cylinder and installed wheel studs. Tomorrow, bleed brakes, refit wheels in the hope they clear the brakes then the possibility of tax and insurance on Monday!
spook
League two here we come !!!
Fri Jul 05, 2013 11:13 pm
Got it out of the garage, washed it, drove it round the block and stuck it down a side st till Sunday.
darkchild
Sat Jul 06, 2013 11:36 am
darkchild wrote:Washed it for the first time in about 4 weeks. :)
Well, an hour's elbow grease with Autoglym's Paint Renovator and Super Resin Polish has improved things. All traces of Navy Blue Fiat Punto paint removed! A couple of dents remain in the otherwise perfect coachwork but an improvement made nevertheless. :)
leeparkes
Sat Jul 06, 2013 12:20 pm
kangman wrote:What wheels are you running??
There my daily BBS reps.. More info and pics here...
http://www.e30zone.net/modules.php?name ... &start=900
milescook
Sat Jul 06, 2013 1:47 pm
After sorting out the coilover heights on all 4 corners, installing balanced wheels with toyo semi slicks, gave it a good thrashign around this awful road https://maps.google.co.uk/?ll=51.857623 ... 9,,0,17.37
:D :D :D
Fancy another go now... :?
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
maggspower
Turbo Farmer Tractor Driver
Sat Jul 06, 2013 1:58 pm
milescook wrote:After sorting out the coilover heights on all 4 corners, installing balanced wheels with toyo semi slicks, gave it a good thrashign around this awful road https://maps.google.co.uk/?ll=51.857623 ... 9,,0,17.37
:D :D :D
One of the best bits of road anywhere :D
milescook
Sat Jul 06, 2013 6:01 pm
:D :D :D
Used to be my route back from Aberystwyth to see my Dad. Such bad luck...
This isn't a bad one either but shh...
https://maps.google.co.uk/?ll=52.477847 ... 15.26&z=13
FinalD
Sat Jul 06, 2013 9:38 pm
Drove it to WWAAAYYYYLLLESSS and back today. Some proper rubbish road surfaces over the border...but I drove it there as a support car (hah, my car breaks more than my mate's) for us track his MX5...awesome day though.
Really want to do more track days but my car doesn't allow for them (cab is like the worst car to try and track). :(
jimbom30cab
Tech 1 freak
Sat Jul 06, 2013 9:41 pm
Nothing on my e30 but helped changed a engine on a mates, whole job done in 9 hours from driving in to driving out, now shattered
The_Haywood
Sat Jul 06, 2013 11:39 pm
started doing some work on my 36 today, had the old linishing disc on the grinder.... linishing away happily not paying attention fully and BAM! off goes the tip of my finger and finger nail split down the middle... lesson learnt... always pay attention when grinding
S14M3
Sun Jul 07, 2013 12:12 am
Purchased OEM skid plate. Continued scavenging for more parts
jmc330i
Sun Jul 07, 2013 12:21 am
jimbom30cab wrote:Nothing on my e30 but helped changed a engine on a mates, whole job done in 9 hours from driving in to driving out, now shattered
Same here, although it was my touring and I swapped one knackered M40 for one (hopefully) less knackered M40.
I dropped the sump pan about 8.30am, found some issues, so carried on and pulled the M40 out and decided to fit my spare M40 - good job I did really... http://www.e30zone.net/modules.php?name ... highlight=
Finished about 9pm this evening, although that did include pulling the shells from the knackered donk to see the damage.
James
'91 325i Sport
'93 318i touring 16v
darkchild
Sun Jul 07, 2013 7:25 am
Filled the tank and had a rare chance to drive it. Norfolk country roads, 80F outside, sunroof open, Bob Marley's Jammin' on the radio...not a bad evening!
jimbom30cab
Tech 1 freak
Sun Jul 07, 2013 7:31 am
Great job jim :)
Gert_8
Sun Jul 07, 2013 6:02 pm
Tested my electric roof. Greased things up, did a bit of crimping on the tensions straps. All left working and finished. Now to start on the other little niggles that are bugging me :D
jimbom30cab
Tech 1 freak
Sun Jul 07, 2013 6:47 pm
Cracking effort mate, respect for fixing that roof, you should go into business doing that, make a fortune :D
Gert_8
Sun Jul 07, 2013 7:10 pm
jimbom30cab wrote:Cracking effort mate, respect for fixing that roof, you should go into business doing that, make a fortune :D
Aw, thanks Jimbom. I'll offer my help to
Anyone free of charge mate. :D Thanks. I think I probably got lucky.
Gert_8
Sun Jul 07, 2013 10:19 pm
^^ must have tracked you on Gaydar. :D
darkchild
Mon Jul 08, 2013 8:31 pm
Took it on a day out to Southwold and Aldeburgh. We actually saw 3 other E30s on the road. A Dolphn Grey Baur, a Lazer Blue Touring and a green 2 door saloon. Must be the heat!
Mon Jul 08, 2013 9:20 pm
Took it to a bodyshop for a quote to repair/replace the rear valance and carry out repairs to the rear panel where the boot floor joins and the rear tubs eaither side.
Unfortunately more than I was expecting so it will have to wait :( Maybe until I get the whole car sprayed and get it all done in one hit :eek:
Tue Jul 09, 2013 7:26 pm
magpie wrote:finally completed the m52 swap
and did it all again .......
G-Bear
Sat Jul 13, 2013 12:44 am
Put on new lollipop bushes and Mondeo Lemforder drop links.. Next up; calibre rebuild..
milescook
Sat Jul 13, 2013 4:21 am
Discovered that left rear coilover has lost all its oil and needs a service from gaz', and the other squeaks like hell so might as well have a look :( hoping to finish fettling my strut brace to go back on later today and finish fire extinguisher plumbing.
Gert_8
Sat Jul 13, 2013 3:03 pm
Went for a glorious razz. Lovely car, which really wants to fly :-).
Flickering oil light on dash didn't flicker, but keeping my eye on that!
Sat Jul 13, 2013 3:04 pm
G-Bear wrote:Put on new lollipop bushes and Mondeo Lemforder drop links.. Next up; calibre rebuild..
What gains do the Mondeo drop links give on an E30?
maggspower
Sat Jul 13, 2013 3:14 pm
They are a better design, and last longer than the e30 item.
Sat Jul 13, 2013 3:27 pm
Interesting, thanks. :)
MrT8064
Sat Jul 13, 2013 4:33 pm
maggspower wrote: They are a better design, and last longer than the e30 item.
Do you have a part number? Thanks
Sat Jul 13, 2013 5:33 pm
found out my replacement m52 is fooked!
Jimbob
Sat Jul 13, 2013 6:00 pm
Finished the brake upgrade, then got it taxed!
bigbird76
Sat Jul 13, 2013 6:47 pm
Changed a leaky clutch master and also the slave then went for a drive.
