uprated gearbox mounts
hongkongfuey
Mad-tango-geezer
Post Tue Jul 09, 2013 10:38 pm
after talking to a zoner about poly gearbox bushes i was thinking of changing mine. have looked at the ones he has and found a couple more mostly in usa. is there any others that could be used to uprate mine? 325 touring. and i did use bmw ones when i put gearbox in so anything else apart from renew the ones you have is the way forward comments thanks.
i did read e21 ones were stiffer?
with cars like mine,
Dave_M3
Post Wed Jul 10, 2013 1:26 pm
Yep, two E21 323i ones are a good upgrade to the standard pair of E30 mounts.
I've used them in a good few cars with good results. Polybushes on the gearbox tend to transmit a fair bit of vibration and noise from the drivetrain through the tunnel
Post Wed Jul 10, 2013 1:30 pm
whats wrong with new standard ones? they can take plenty of track work. poly just transmits all vibrations into the cabin
hongkongfuey
Mad-tango-geezer
Post Wed Jul 10, 2013 8:37 pm
Just fancy a change and want to upgrade si
hongkongfuey
Mad-tango-geezer
Post Mon Jul 29, 2013 8:59 pm
I've put the e21 mounts on. One of my mounts was on its way out . Feels a lot better and more solid. Seem to change gears smoother?? Could be placebo . And they are febi ones about £5 each :)
