Ews wiring?
fearlessphil
Post Sun Jul 07, 2013 10:54 pm
i bought an s50 conversion package it was in a running car so i know it works im just a bit puzzled how it all goes together?
this is what ive got
and this is where i think it goes
What im unsure of is do i splice them in or do i cut the wires solder them in and if so which side of the plug
also im guessing the brown wire with the washer connector in the earth?
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Jul 08, 2013 6:36 am
willnz wrote:The WIKI has all the info you need to connect it up.
http://www.e30zone.net/e30zonewiki/index.php/EWS
fearlessphil
Post Mon Jul 08, 2013 8:15 am
is the m52 ews the same as the s50?
jmc330i
Post Mon Jul 08, 2013 9:07 am
Yup, should be the same.
I didn't realise that EWS wiring info was in the wiki.
As per you other thread, it looks like you've bought my old conversion, that's my EWS wiring!
I'm not sure what Shane has labeled on the two inline fuses, but they only need hooking up to power - one live all the time, the other live when the ignition switch is in the acc, run and start position (from memory I added the wire directly to a terminal on the ignition switch itself).
The only wires you should need are those that are free. All the other wires that are obviously taped up aren't needed - some is E36 specific stuff, the others are for the starter inhibitor circuit, which I decided not to use - the car will turn over, but not fire unless the key is in the antenna loop.
Once you have it wired in and running, you can pull the unused pins from the yellow plug to tidy it all up, which is something I never got round to doing!
James
'91 325i Sport
'93 318i touring 16v
