Next week work starts in earnest on the back end of my car. I've got a rear beam, diff, trailing arms and braking system ready to put on.
What problems can I expect?
Arse end
bab-91
I had major problems removing the exhaust, the bolts where badly corroded.
So I would recommend cutting them off, if you face the same problem.
It can be a 5 minute job or hours of swearing blue murder.
IG - bab91
IG - bab91
scjimbo
Mine look buggered too. Ill take the sparky spanner to them then.
Top advice mate
Top advice mate
bab-91
If in doubt use the angle grinder, failing that, attack it with a blow torch
IG - bab91
IG - bab91
scjimbo
Heros use the gas axe. I had fun with the beam bushes and that particular piece of equipment.bab-91 wrote:If in doubt use the angle grinder, failing that, attack it with a blow torch
Cypriotgeeza
yea definantly worst part of mine was the seized on subframe bushes! and seized in handbrake cables in the hub! A lot of swearing went into mine but what a difference it made to the drive after!
http://www.e30zone.net/modules.php?name ... c&start=50
the rear end pics are on page 3
Check my M30 build threads:
New Daily : viewtopic.php?f=34&t=285452
fearlessphil
yeah subframe bushed on mine were a right dick!
dooce
subframe bushes are no problem with the right tools.
http://www.e30zone.net/modules.php?name ... 36#2630836
Cypriotgeeza
if the bushes aren't seized to the bolt or if the bolt knocks through the topdooce wrote:subframe bushes are no problem with the right tools.
milescook
Lots of potential issues. Here were mine
Also please help the race budget by watching some videos
https://www.youtube.com/cookracinguk
