M62 engine loom. What bits?
padi
Post Sun Jun 30, 2013 6:54 pm
Hi Guys,
As the title really! I going to collect an engine and manual box from a 1998 540 m62 next Saturday morning. I just want to check exactly what I need from it.
Obviously the ews ecu (white box mounted to the steering column?) antenna (around the key) and the chips from the two keys.
The ecu from the drivers side engine bay and all of the wiring loom inside the engine bay including the c101? Plug.
What do I need from inside the car? The clocks and clock loom? Is there any wiring loom inside the car i need?
I don't think I need the fuel pump?
The propshaft.
Is it worth getting the clutch cylinder from the pedals?
I'm going to get the gearbox brackets and as much other bits, hoses and wire connectors etc as I can but am I missing anything? The engine is coming with all the ancillaries, exhaust and everything so its all there.
Any help would be great!
Cheers Chris.
