Front Top Mount Bearings
ItalianM3
Post Thu Jan 05, 2006 10:25 am
I was going to replace the front top mount bearings while I did the suspension change. I went to Euro carparts and got some new top mounts front and rear, thinking they would come with the bearings, the part number is: 3133139452 for the front.
I cant seem to find the bearings on the etk I can see them if I look in the engine bay so I know they are there, anybody have any ideas or know the part numbers?
Luke
GDBN
Post Thu Jan 05, 2006 10:51 am
The bearings are integral in the rubber mount. Or should be ... they are with the Febi Bilstein ones I got.
G
Geeman
Post Thu Jan 05, 2006 11:01 am
Yeah... the fronts should come with the bearings built in. Do not worry.
Giles
ItalianM3
Post Thu Jan 05, 2006 11:06 am
Where did you buy your ones from? I got mine from Eurocarparts and they have NO intergrated bearings, thats the only thing I am worried about!
GDBN
Post Thu Jan 05, 2006 11:26 am
Bought mine over here in Denmark. There should be a metal ring in the middle (that the shock slides through) with the bearings around the outer edge.
Can you take any pics ??
G
Geeman
Post Thu Jan 05, 2006 11:49 am
I always use GSF for any non-OEM part
