Central bloody locking !
BATTS91
Post Thu Jun 27, 2013 5:29 pm
Ok so in my Tourer the drivers actuator failed , to which i disconected for a few days .
Now at first all locking resumed fine apart from the drivers door of course .
Then ready to ho to an mot the boot nor petrol cap unlocked !!!
I managed to open the petrol cap by pushing the pin back in .
Now ive replaced the actuator but only the front two doors lock and unlock on the central locking , No rear doors boot or cap .
Now i can unlock the rear doors by hand with the door pins but im stuck with the boot being locked due to it being a different key .
Ive done the ol red/black wire trick and tryed the big locking relay from my 2door .
Any suggestions ???
hongkongfuey
Mad-tango-geezer
Post Fri Jun 28, 2013 6:40 am
I maybe wrong but don't you have to hold the key in the lock or unlock position for 20 seconds?
with cars like mine,
BATTS91
Post Fri Jun 28, 2013 1:48 pm
Errm ive not heard of that . Is that just to lock the door or to reset it ? :/
BenHar
Post Fri Jun 28, 2013 2:52 pm
hongkongfuey wrote:I maybe wrong but don't you have to hold the key in the lock or unlock position for 20 seconds?
I think you may be wrong.
Ben
BATTS91
Post Sat Jun 29, 2013 12:38 am
Ah thankyou very much sir . :)
Does anyone have any ideas on fixing the whole problem and getting it all working as it should be . ?
BATTS91
Post Sat Jun 29, 2013 4:35 pm
I found the green/violet wire on the c/l unit in the foot well and ground it using some wire but still no boot unlocked :/ .
I have failed to mention there is an alarm fitted to the car . Clifford 650 . Pressing the fob to unlock is the same as the key .
BATTS91
Post Mon Jul 01, 2013 7:58 pm
Anybody ? .
BATTS91
Post Thu Jul 04, 2013 3:26 am
I tryed the green and violet wire the ground again today with the c/l box unplugged and the boot opened and now functions how it should .
But the rear doors still dont lock on the key/central locking .
BATTS91
Post Thu Jul 04, 2013 3:27 am
Anyone have ideas ? Is there a wire i can do the same for the rear doors?
