High comp, low comp? 2.5
Smithy89
What is better in your opinion and how can you tell the difference? As I'm looking for an engine at the moment, does the high comp have 2.5 2.7 stamped on the head?
kam-325i
you are looking for 25E6 or 25K6 on the block.
The E is for the early high comp, K for the later lower comp engine.
maggspower
- Turbo Farmer Tractor Driver
A high comp will usually only have 2.5 stamped on the head, but anything is possible.
The best way to tell is on the flat section near the base of the dipstick there will be a code
25 6 E 1 - 9.7:1 comp
25 6 E 2 - 9.4:1 comp
25 6 K 1 - 8.8:1 comp
The higher compression lumps are without doubt a bit more pokey.
HTH
HTH
Contact: theengineshedonline@gmail.com
kam-325i
bugger, wrong way around !!
