325i CAB CUTTING OUT
tumshie
Post Sat Jun 22, 2013 7:49 pm
Firstly I'm sorry if you've already covered this before but I'm a relative beginner. I put my E30 325i Cab in for its mot last week (after being garaged over the winter) then on the way back it was stalling while I was waiting in traffic. This had never happened before, infact in the last year which I've owned it, its never let me down. This has steadilly worse to the point that it cuts out when I'm driving and now the symptoms are as follows. Starts first time from cold and runs for 2-3 mins then dies, restarts first turn then dies after 30secs. It does this 2-3 times then wont restart until its sat for 5-10 mins. I changed the fuel filter, shorted the pump and it runs although I supose it could be on its way out. Any pointers would be much appreciated.
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Jun 22, 2013 9:54 pm
Could be quite a lot of things, but the first thing I'd do is pull out a spark plug and see if it's sooty-black. I have a feeling your car is running rich, and this is often caused by something called the Blue Temp Sensor:
http://www.e30zone.net/e30zonewiki/inde ... emp_Sensor
Post Sat Jun 22, 2013 10:43 pm
If it's a post facelift engine, I'd suspect the C301 plug and socket before the sensor itself.
Wiki testing procedure is poor. The sensor should be tested at the ECU plug first, before you disturb any wiring under the bonnet.
tumshie
Post Sat Jun 22, 2013 11:04 pm
Thanks I'll try these out first thing in the morning,
tumshie
Post Sat Jun 22, 2013 11:06 pm
Brian, I've just read your post again unfortunatly its a pre facelift G reg
Post Sat Jun 22, 2013 11:46 pm
If it's 'G' reg., it's post facelift in the engine department. It's only the body shell and trim that lagged behind in the upgrade program.
tumshie
Post Sat Jun 22, 2013 11:48 pm
thanks i'll check in the morning
Grrrmachine
Post Sun Jun 23, 2013 7:30 am
Brianmoooore wrote:
Brianmoooore wrote:If it's a post facelift engine, I'd suspect the C301 plug and socket before the sensor itself.
Not the C191 under the intake manifold
You could well be right there!! This is what happens when I try to post technical things while engrossed in the live Le Mans TV coverage!
Post Sun Jun 23, 2013 9:48 am
And the above is what happens when I try to "quote" a post while engrossed in Le Mans coverage, and "edit" a post instead!!!!
C191 is what it should have read, not C301.
Zone member Jan Mardenborough is now running in a podium position at Le Mans, 3rd in class, and a magnificent 9th overall.
tumshie
Post Sun Jun 23, 2013 9:13 pm
given it check over everthing mentioned but it turns out that there is only 7-8v at the coil, tried changing the relays and the cps but its none of those. basicly if you run a live direct from the batery to the coil the car runs perfect. I've just got to find out where the voltage is dropping out, any sugestions
Post Sun Jun 23, 2013 10:07 pm
Probably an immobiliser connected in the feed. Not necessarily one you know about or necessarily just one.
tumshie
Post Mon Jun 24, 2013 5:14 pm
bingo, you were right it was the immobiliser within the obc that was the problem
