why cant i find e28 m535i mounts
Nas80
Post Thu Jun 13, 2013 11:36 am
no one bloody stocks these anymore! ive tried euro car parts, gsf, mister-auto, smeiddmann (they list it but out of stock), Wallach and nesche don't do e28s, er variety of other places (local motor factors etc)
only places that get them but have to import them.
Dealer can get em but £45 each
The costwolds guys are £40 each
the bmminiparts are £40 each
Meh, anyone recommend anywhere else?
BATTS91
Post Thu Jun 13, 2013 12:03 pm
e28 M5 Mounts ..
http://www.eurocarparts.com/ecp/c/BMW_M ... 545&000461
But you need two left ones iirc
Post Thu Jun 13, 2013 1:30 pm
BATTS91 wrote:e28 M5 Mounts ..
OR: http://www.carparts4less.co.uk/search/337110070/p/home
Same part, same box, off of the same warehouse shelf.
Nas80
Post Thu Jun 13, 2013 2:23 pm
awesome thanks lads. the local ECP guy didn't even know what an e28 was! lol thanks again for the help.
Post Thu Jun 13, 2013 2:33 pm
Tut tut Nas, you give up so easily. :mad:
mr_dink
Post Thu Jun 13, 2013 3:09 pm
E34 M50 mounts work as well.
I have a pair of 318IS mounts here somewhere which would also work.
PM me if interested.
Nas80
Post Thu Jun 13, 2013 5:09 pm
I already ordered new ones, I read on the internet that although e34 ones work they aren't made of the same hardness of rubber?
lol @ rav - at least the correct engine is going into the correct shell - e21 m52b28 ftw!!! :cool: winkeye
Post Thu Jun 13, 2013 6:37 pm
LOL, you know those engines don't like E21's Nas, one's already cooked the car :D
Andeep
Post Sun Jun 16, 2013 8:39 pm
Is there any different between E28 M5, M535i or 535i engine mounts?
Jimbob
Post Sun Jun 16, 2013 8:58 pm
I used these:
https://www.carparts4less.co.uk/search/337110070/p/home
Not sure how I came across them though!
jmc330i
Post Sun Jun 16, 2013 11:11 pm
Andeep wrote:Is there any different between E28 M5, M535i or 535i engine mounts?
M535i are the same as any M30 mounts.
The E28 M5 (S38) has a different mount on the exhaust side, possibly down to the extra weight of the 24v head (considering the engine tilts that way) and extra heat from the 6 branch. That's why the M5 mounts are recommended for S50 swaps, although I guess the same could be said for M50/52 swaps.
James
'91 325i Sport
'93 318i touring 16v
Andeep
Post Mon Jun 17, 2013 1:40 pm
Searching the part number 11811128932 on realoem, it says that the left mount is the same for E28 525i, M5, M535i:
http://www.realoem.com/bmw/partxref.do?part=11811128932
jmc330i
Post Mon Jun 17, 2013 1:58 pm
Yup, that's correct, the left side mounts are the same. It's only right side (exhaust side) that differs on the M5.
James
'91 325i Sport
Andeep
Post Mon Jun 17, 2013 2:15 pm
Will be ordering a pair of left side ones then.
Would you recommend getting them from BMW or from ECP/similar?
fonk
Post Sat Jun 22, 2013 12:29 pm
So why you cant use e28 right mount? Why only left ones? Got myself a pair ( only paid £10) , been told on this forum to get mounts from e28 :?
Andeep
Post Sat Jun 22, 2013 12:34 pm
Can someone just confirm that I need 2 of these mounts:
http://www.eurocarparts.com/ecp/c/BMW_M ... 41e&000461
fonk
Post Sat Jun 22, 2013 12:43 pm
Andeep wrote:Can someone just confirm that I need 2 of these mounts:
Just messured both mounts right and left on every angle. Both are spot on the same my came out from
E21 635csi , and they look exacly the same as on eurocarparts web.
jmc330i
Post Sat Jun 22, 2013 2:29 pm
fonk wrote:So why you cant use e28 right mount? Why only left ones? Got myself a pair ( only paid £10) , been told on this forum to get mounts from e28 :?
The E28 M5 right side mount is more expensive (and BMW only iirc), so most people will go with 2 left side mounts.
I know the M5 right side is needed on an S50 conversion, but nobody has confirmed if its needed on M50/52.
Fwiw, I've used the E28 M5 rightside specific mount on the three M50 conversions I've done.
James
'91 325i Sport
jmc330i
Post Sat Jun 22, 2013 2:40 pm
The 635i uses the same round mounts as the 535i etc, so that should be fine.
James
'91 325i Sport
Jimbob
Post Sat Jun 22, 2013 2:41 pm
I used the 635 mounts on mine without issue.
Andeep
Post Sat Jun 22, 2013 3:26 pm
So it is defo 2 of these that I need? Im not sure which side these are from:
jmc330i
Post Sat Jun 22, 2013 3:45 pm
That's the normal M30 mounts, left and right side (used only on the left side of the E28 M5). That seems to be what people are using on the M50 conversion.
James
'91 325i Sport
