Been fiddling with the electric roof during lunch time today. As you may already know, I have been successful in getting the roof to work. Only problem is that it gets to this stage.
The horseshoe is sticking at this point, during the opening stage.
My suspicion is that the levers against the back wall of the storage compartment are not moving up and down as they should.
In the image below, You can see these two levers - the front one is oval shaped, which is connected to the rod that pushes the horseshoe up and down, as the lever behind it rotates, left and right, when the roof is raised or lowered.
It is the rear lever that I need the answer for. If you note, there is a "bar" of metal that is part of it, which stops the oval shaped lever from rotating further.
Can someone kindly post an image of this set up, please, when the horseshoe is in the fully open position? I need to understand how these two levers are positioned relative to each other when the horseshoe is fully open at 90 degs.
Ignore the lashings of copper grease!:D
Thanks.
