I have problems with my 323i, It doent want to run proply if it does it doest last long. I want to know if anyone has put bike carbs on one I know bogg bros will make a manifold.
Any advice would be nice ??
323i on bike carbs
jmc330i
Your 323i has bike carbs and doesn't run well or your 323i doesn't run well and you want to fit bike carbs?
The fact you say about the bogg bros manifold makes me think you're wanting to fit bike carbs...
In which case, that might not solve your running issues and may actually make it worse. You would be far better off solving the running issues before you try to modify anything.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
tonbridge_e30
I am wanted to run bike carbs, I'm sure the running problems are to do with the inlet side of things and fuel. If I go to bike carbs I will get rid of all the inlet side and the fuel side and start again
