So far I have found this list, just need to confirm that this is right for an e34 m30 (list is for m50), and I'll sort it on my car taking some photos along the way
E34 M50 Tu E30
1/ blue/white (oil level, dynamic) 2/ green/yellow
2/ blue/yellow(oil level static) 10/ blue
3/ red/white (ABS supply) 20/ red/yellow
4/ black/blue (aircon)
5/ black/grey (aircon)
6/ purple/grey (aircon)
7/ black/purple (drive away sigle for E34 OBC)
8/ grey (engine fault) 12/ grey
9/ NC
10/ NC
11/ brown/yellow (water temp)
12/ brown/purple (water temp) 4/ brown/purple
13/ green/purple (fuel pump) 13/ green/purple
14/ black/white (speed to inst. cluster) 14/ black/white
15/ black/green (unloader relay) 15/ black/green
16/ white/yellow (Rx data)
17/ white/purple (Tx data)
18/ black/yellow (starter) 18/ black/yellow
19/ white/green (SI. reset) 11/ white/green
20/ black (engine speed to cluster) 9/ black
21/ Green (ignition) 7/ green
22/ green/white 6/ green/white
23/ brown/grey (oil pressure) 5/ brown/green
24/ white/black ( fuel rate to cluster) 8/ white black
25/ blue (ignition light) 1/ blue.
from this on an e30 pin 1 is ign light and pin 9 is tacho
