Tech 1 sport semi resto ( all parts removed will be reused )
gaszman
Mon May 06, 2013 11:50 am
just got a few bits to put on the old girl
full engine service
feed pipes for the fuel and vent tank
and pipes to this from the tank both rear hand brake covers
a rear pad sensor
tank sender gasket
new tech 2 gator
clips and bits
a freshly died black carpet sweet
a uncracked dash ( thanks trev)
and a fuel tank just in case
back to a busy couple of weeks
jimbom30cab
Tech 1 freak
Mon May 06, 2013 12:07 pm
Great thead, lots of pics pleased
Subscribed :D
gaszman
Mon May 06, 2013 2:06 pm
when it starts i will lots of f**s will be had especially on the fuel pipe all brackets seized
scottshot
Tue May 07, 2013 3:51 pm
hi buddy, where did you source your fuel tank from?
im after one myself and that looks spotless
gaszman
Tue May 07, 2013 4:17 pm
off here and yes shes a goodun wont know if il need it till i start taking bits off :mad:
Tue May 07, 2013 4:40 pm
Watching with "Hawk" eyes :D
gaszman
Thu May 09, 2013 10:47 am
gonna be using the fuel tank just found my fookin leak shit shit shit :x
gaszman
Fri May 24, 2013 11:56 am
ok gonna start now
gonna try and reuse as much as i can ( dont have a pot of gold )
started today removed the front vallence so i could get the old girl on ramps , then out with the exhaust and heat shields then i had a good look at the old girl . 210,000 miles a little corrosion but not bad
pics will follow also got a spare rear beam have new bushes will replace if nessisary as i do not have the tool to do this .
jimbom30cab
Tech 1 freak
Fri May 24, 2013 12:25 pm
mate, i'm pretty local if you need a hand with anything
cheers
jim
gaszman
Fri May 24, 2013 4:07 pm
cheers jim
as i said all parts that are removed will if poss be cleaned and reused
ready for the ramps ( have to remove front skirt as it catches )
rear heat shield after a clean and spray
cntr heat shield
nice aliminum one standard ??
front bumper dont fit
need help on a fix for this
diff bush ok i think
rear beam bushes again all good i think
this pipe is fooked so is a replacement avalable
thats all for today hope to get prop off then move on the the tank
gaszman
Fri May 24, 2013 11:04 pm
so fuel tank out and it was fooked the seam around the front had split and the pipe for the fuel in take had come away and the gasket for the sender was in three bits .
new tank in tommorow will post pics later :mad:
jimbom30cab
Tech 1 freak
Fri May 24, 2013 11:07 pm
That bumper fit is better than factory, great work there, can you do mine next ???
gaszman
Sat May 25, 2013 7:52 am
ok so finished at 10.30 tank out
prop with gilbo
fuel leak i think so
thats where the tank bolts up
just before removal and the pipe between the tanks is fooked , a trip to hypehose today for a replacement i hope
polsta
Sat May 25, 2013 8:07 am
Good work Dave , get some fertan and get busy with it on the surface rust etc and any rusty fittings or hard to reach bits, is that a brand new heat shield ? I need to get one, looking forward to more pics
gaszman
Sat May 25, 2013 8:36 am
no mate just cleaned the one from the car should be ali on ours unless its been replaced with a facelift one , its lighter veroom veroom
polsta
Sat May 25, 2013 8:43 am
Looks decent , had a look at mine when dropped and polished the back box it's a bit crusty but for now
When are you doing the dash ? Any chance you can please take some pics of it all at either side as you remove the trim etc ? Having a bit of a mate trying to get mine right above the glove box
When are you looking at being back on the road ?
gaszman
Sat May 25, 2013 8:44 am
poss middle of the week but i dont need the car for two so im gonna plod along have a weeks holiday so in theary i could be all done by fri
gaszman
Sat May 25, 2013 5:21 pm
tank in she a little holey but no more .
on the the metal fuel lines
SteSE
Heading for the Naughty Room
Sat May 25, 2013 7:18 pm
Your rear beam bushes have collapsed. New ones required.
87.5 Impact FM
PS3: gary_bunter
1986 325i resto - M52'd
C plates are fastest
gaszman
Sat May 25, 2013 7:30 pm
will be getting done tues wens
gaszman
Sun May 26, 2013 12:51 pm
ok next up date the pipe between the tanks from hypehose pattern is 30 pound trip to bmw oh yes 44 pound what .
so repair my self
now change from dull grey to black
now the change to black
looks so much better
brakes next oh joy
gaszman
Sun May 26, 2013 2:17 pm
a little look at the fuel tank
so new tank fitted
gaszman
Sun Jun 09, 2013 10:10 am
so after being just too lazy cleaned the engine bay after two weeks after the bady shop came up ok
this last photo is what happens when the engine hoist lets go when removing the engine wich i did in 2009
guess i will have to do something about it sometime
polsta
Sun Jun 09, 2013 10:27 am
could you get a block of wood and a weighted rubber mallet and beat it straight ? paints4u touch up paint is good for those areas and chips etc, as are new grille clips if yours are rusting, ony penuts to buy
carpet looks good :cool: looks to be in nice condition aswell, liking the leather handbrake gaitor :cool: (want)
gaszman
Sun Jun 09, 2013 10:36 am
the gaiter was an ebay special cheap from a guy in soton fitted well bit of trimming , goes well with me new gearstick gaiter and knob
polsta
Sun Jun 09, 2013 11:43 am
was it "topgaitors" ? are they worth buying did you get the handle aswell ?
gaszman
Sun Jun 09, 2013 12:48 pm
handle was dealer fit and yes top gaiters
gaszman
Mon Jun 10, 2013 9:37 pm
so tonight i changed my rear hand brake dust cover nice easy job . not some one in the past had fitted the drive shaft nut and retaing washer round the fooin wrong way so i could not get a socket on the nut at first ,. managed it in the end after fitting every thing hand break is so much better will do the otherside with pics
polsta
Wed Jun 12, 2013 5:38 pm
flash git dave !! any news on these ?/
http://www.ehattons.com/61277/Corgi_Col ... etail.aspx
gaszman
Wed Jun 12, 2013 9:44 pm
still waiting for mine mate
gaszman
Thu Jun 13, 2013 8:10 pm
Thu Jun 13, 2013 9:21 pm
Wheres the brown patches for autheticity Dave? :wink:
Seriously though, Nice job!
gaszman
Thu Jun 13, 2013 9:56 pm
cheers trev
gaszman
Sun Jul 28, 2013 9:52 am
ok a little update changed the rear beam bushes with the help of dave t special tool .
and all in all not a bad job , best to do one side at a time to allow the beam to drop one side to allow access .
started by removing the wheels , then the 4 6m Allen key bolts that hold the bottom plate in place . then undo the 22m nut at the bottom .
then using a hitting stick with the nut still on the bolt tap the bolt through mine came out no prob .
then prom i had was the mounting was siezed in the reses in the chassis so long bar pulled it down . then using the removal tool one side out in two parts inner and outer. new one fitted little fairy liquid sweet .
same for the other side
just got to do the engine mounts and a cam belt
gaszman
Sun Jul 28, 2013 10:14 am
just some pics of the bushes pretty fooked
nice and clean under the tank
[URL=http://s147.photobucket.com/user/gaszma ... c.jpg.html]Image
on the last pic you can just see where some one has cut the rewelded the cup the bush sits in .
