Engine numbers , compression ration ? Ok to turbo ?
shane281189
Post Wed Jun 12, 2013 12:51 am
Just wanting to check that my engine is ok to turbo took it apart today after headgasket went can anyone tell me what compression ratio this engine is ? Also the pistons are dished down wards are these standard pistons, piston 230 0987 83.98
Engine block numer-1278 821 205 87
Head number-1705 885
kam-325i
Post Wed Jun 12, 2013 9:58 am
What size engine.....
shane281189
Post Wed Jun 12, 2013 10:19 am
325i ??
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Jun 12, 2013 10:25 am
Most of the info, such as compression and pistons, is in the Wiki:
http://www.e30zone.net/e30zonewiki/inde ... 20#Pistons
shane281189
Post Wed Jun 12, 2013 1:34 pm
Cheers I looked I'm still confused tho the number has 27 at the beginning would that mean its a 2.7 ?
hongkongfuey
Mad-tango-geezer
Post Wed Jun 12, 2013 2:14 pm
Look on block inlet side next to engine mount. Should say something like 625e or k . E is early engine higher comp k is later engines lower comp. And on the head it will say2.5/2.7 for a 325 head
with cars like mine,
shane281189
Post Wed Jun 12, 2013 8:04 pm
It's a "e" :( what to do ......
HairyScreech
Post Thu Jun 13, 2013 9:05 pm
sell it and buy a K or just do it anyway, unless it is an e1 then it will still be below 10:1
ross2009
Post Fri Jun 14, 2013 6:33 pm
ive already told you all this shane
the pistons from a high comp and low comp look identical there both dished with 2 valve cut outs you have to measure the depth of the dish to find out which one is which theres 1.1 mm difference from either piston the cr of your engine is 9.4-1 which is to high for boost
unless you know they came from a late cat 25 6k engine which is 8.8-1
Turbo M20
v8 project 6.0 twin turbo
