what worked best for you?
Jamie8GTi
Post Thu Jun 13, 2013 3:05 pm
hello guys im doing an m50 swap on my old m40'd 316i and as far as box, prop and diff what have you guys found to be the better combination?
when i bought the non vanos m50 lump the bloke threw in a getrag e36 box and dual mass flywheel... ideally i'd like to keep costs from heading skyward but what would you do?
would need to buy new clutch kit and slave cylinder as both are missing.. or would i be better off sourcing an e30 box?
the 316 was equipped with a getrag box.. i can find part numbers later on along with the usual smallcase open diff.
I'm not hugely familiar with bmw's and maybe have taken on a bigger job than i should have but either way this bad boys going in..
any input would be appreciated :)
BATTS91
Post Sat Jun 15, 2013 3:27 am
Me , i would use the e36 box with a lightened m20 fly ,starter ,clutch .
There are other ways of doing it tho . Ie m42 box ect
E30-Doc
Post Sun Jun 16, 2013 12:13 pm
I am with m52, m20 lightweight fly and clutch, m40 g240, m20b20 prop, 3.64 diff
Andy325i
Post Sun Jun 16, 2013 12:15 pm
M52, M52 gearbox M20 lightened flywheel, E30 M3 prop :)
