pre/post face lift front lights.
zimmermatt
Hi my car has pre face lift front lights which are incorrect so want to get smilies. are the clusters the same and can just get the lenses or do I need the whole set up? thanks matt.
- Brianmoooore
Need the whole set up, including the plugs for the lights, which will need changing (depending on what was done to fit the wrong lights).
Grrrmachine
- E30 Zone Wiki / Team Member
Are you absolutely sure the car has the wrong lights? Do you know that for 1988 there were non-smiley headlights for the first facelift cars, called "bullseyes"?
http://www.e30zone.net/e30zonewiki/inde ... Headlights
zimmermatt
ah i see. now thats interesting, it is a 88. Its had a front end repair so I assumed that the wrong lights had been fitted. If theyre original then I may as well keep them as is. Thanks for the help
- Brianmoooore
Both 'smileys' and 'bullseyes' use a lens to focus the light, with the 'reflector' for decorative purposes only (except for the parking light).
Pre face lift lights use a reflector and prismatic front glass to make some attempt at creating an acceptable beam pattern.
zimmermatt
Mine are bullseyes so am happy with that!
